t-rex 600 le clutch change
  • t-rex 600 le clutch change
    Has anyone changed the standard clutch in there t-rex 600 for the quick uk one? does it stop the engine from screaming before it engages?
    Thx in advance Ross
    Troll buster
    Mines the standard clutch still, gets better as time goes by
    James
    Sponsored by
    Align-Trex.co.uk
    Optifuel/optipower
    MKS servotech
      Mine's the standard clutch too. Don't recall my engine ever screaming prior to engaging, but I may be wrong. Are the LE clutches different to the NSP ones?
      Martin
        Im sure there was a post saying that the LE ones were slightly smaller.
        x 3
          yea it seems to be a common le thing,, BOTH mine do it but as james says they do get better with time,
            Mine screams before engaging, just noticed after changing whole clutch stack. It gets better because the clutch springs, which is the moment before it goes snap. It really needs a thicker liner, or a bigger clutch.
              apparently the raptor liner is a better fit and stops the problem??
                Could be. However, I just checked the Align manuals for the pair of them and the clutch, bell and liner are the same part numbers.
                Martin
                  Heres what a QUK clutch can do for your LE
                  [ame=http://www.youtube.com/watch?v=YRc_OgRKTXA]YouTube - Trex600LE with Quick UK HD Clutch[/ame]
                    Late clutch engagement issue on 600 LE - HeliFreak
                    x 3
                      Odd. Must be some kinda manufacturing defect, or a redesign?
                      Martin
                        If its screaming the clutch liner is to big and was common place on very early 600N's. Just a matter of time till you pop the shoe.
                        This issue seems to have mysteriously re-appeared after Align addressed it within a couple months of launch.
                        Problem is the same, the liner to clutch gap is to big. If your carefull or just plain tight like me, you can prise out the originial liner and re-use it.
                        To get the correct gap just add a strip of paper between the bell/liner to bring the dia down. The extra layer of epoxy + layer of paper is about right (5min epoxy is fine BTW)
                        You will have to remove a slither off the end of the liner as its dia has reduced. 2 wraps of insulating tape on the clutch shoe should give you a neat but sliding fit for the correct gap.
                        A raptor 90 liner is another alternative for those with a deeper pocket and less patience
                        SPARTANRC Team pilot
                          when i built my 700le a couple of weeks ago i replaced the clutch with a quick uk one and the difference is unreal, it engaged as it should although i didnt know if there was the problem with the 700 le as there seems to be with the 600le
                          Troll buster
                            Part number PV0204... £2.98?
                            I've heard about replacing the liner for earlier engagement.. but its still new to me and seeing how I go first!
                            Eddie
                            Velocity 90 FBL BeastX V3
                            Trex 600 LE FBL BeastX V3
                            Trex 500 EFL Pro BeastX V3
                            Fusion 50 FBL
                            VBar
                            All powered by a DX8
                              Well i decided to changed the align clutch in my 600le last night for the quick uk one and just put 5 tanks though it today, the difference is massive, where as before it used to scream before engaging its now very smooth.
                              I would reccomend anyone changing the original clutch to install the upgrade.
                              Troll buster
