align 2-1 reg or servo
  • align 2-1 reg or servo
    went flying on sunday first flight since rebuild, after tail pitch slider snapped on my 600le 5-6 flights intotal all ok
    went to the field to day switch on my tranny then the heli found that all 3 swash servo's not working
    on investigation found all 3 align ds610 servo's have failed ,checked the voltage output from the align 2-1 reg reading 5.8 volts
    dose any body no of any issues with these regs or servo's as i not used these before
    beginning to think align quality is poor
    kasama srimok 90n
    T rex 700 Ys91sr futaba bls 452 GY520+bls 251 aerospire gov Fromeco reg
    Futaba 10c
    empty bank account
    Definition of your failure? No sign of power to servos or erratic movement or sound but no turning of wheels? The align wheels are notorious for being sacrifical on their splines. Have you checked using another Rx?
    PGK
      no movement from the servo no noise and you can turn the servo wheel with no resistace
      swop with futaba servos all working ok
      but what is odd i did a servo test with my tranny and it showed the servo moving on the test but they were still
      kasama srimok 90n
      Futaba 10c
      empty bank account
        If you're viewing tx output then that's meaningless..unless you have some fancy feature i don't know about that allows you to attach a servio directly to the tx. It jts means the tx is sending iof.. not that the rx is receiving or the servo responding.
        Certainly odd if you burned out the motors on all 3 cyclics at the same time. suggests one went under extreme load and the current draw shot way higher than I'd have thought the 2:1 could deliver..or they were all jammed and went down like dominoes. I'd be very tempted to pull one apart, remove all gears and case and see whether there's anything happening when plugged in...(just make sure it's all on insulation)
        PGK
          There's no way you could have burned out 3 servos at the same time. the fault has to be common to all three, ie reg or rx
          T-Rex 600N Pro x 2 - T-Rex 600N Sport - Rappy 50 - Hughes scale (Rappy 50) - Hughes scale (Century 50)
          Jet Ranger scale (GH 61) - Mini Titan - mCPx - A "few" canopies
          www.Cano-Fx.co.uk
            fitted a set of futaba servos everthink seam to be ok
            checked the voltage out of the reg and its 5.8 volts
            kasama srimok 90n
            Futaba 10c
            empty bank account
