Just look at those nice alloy FBL servo disks too.... Looks like you'll need to source your own ESC and its available as 2 versions - as a super combo with all the gizmos, and as a kit with motor with NORMAL flybar L....no ideas on cost !
700E Product Design Features
1 wholeMetalHigh LordRotorControl group, with excellent rigidity and excellent control accuracy
2 large-scale competitionHelicopterDesign, static and dynamicFlightJieyou high performance
3 new adjustable span control of the metal aroundRockerAnd arm movements control group, can not balance the wing corresponding to 3G systems and balanced wing system to improveServoDevice resolution, to make flying more precise
4 first 3K Battery side and slide one piece design, not only for easy removal, also provides excellent protection of the battery, while both side panels to enhance rigidity and increase the focus of the advantages of the battery
5 on the home-styleMotorBlock design, so that the body center of gravity more precisely, can greatly enhance the flexibility of 3D, in addition to a strong air current in the main rotor are also providedMotorExcellent thermal environment
6 module 1 with the main gear, main gear greatly enhance the capacity of
7 unique fixed bearing design of the third motor, gear motor to turn in the great outer radial force, to provide support for mandrel absolute power, can significantly reduce the high transient torque shaft deflection caused by the instability backlash changes, and can completely avoid severe tooth brush, so as to enhance the strength and drive the main gear. motors performance, and enhance the high-powered enough outside the Bird pivot motor weakness, and effective to ensure the best life
8 disassembly to facilitate the design of home-style ESC holder can use the powerful main rotor airflow, providing excellent thermal environment ESC
9 new lightweight Denso holder H section structure, not only has a protective effect, people-oriented design allows for the configuration of electrical equipment organized and convenient operation set
Advanced Stained Glass 10CanopyTo a new four-point earthquake shock fixation, more convenient installation and removal
11 + -15 degrees pitch travel with excellent 3D flight performance and super-explosive
12 CNC secondary machining the main gear, with excellent accuracy and stability
13 resistant to high speed thrust bearingSpinBlock design wing clip
14 using high-performance shaft drive design and high texture of high-strength carbon fiber tail pipe 3K
15 3K carbon fiber bilateral board, simple structure, high strength, easy assembly and maintenance
16 tail group, tail pipe and tail pipe support frame are made of high strength carbon fiber material
One-way high-torque 17-resistant structural design of the bearing
18 New Lightweight Tripod
700E 3G
Specification:
● Length: 1328mm
● Height: 408mm
● Main Blade Length: 690mm
● Main Rotor Diameter: 1562mm
● Tail Rotor Diameter: 281mm
● Motor Drive Gear: 12T
● Main Drive Gear: 115T
● Autorotation Tail Drive Gear: 104T
● Tail Drive Gear: 24T
● Drive Gear Ratio: 1:9.58:4.33
● Weight (With Motor): 2830g
● Flying Weight: Approx. 4700g
700E 3G
Specification:
● Length: 1328mm
● Height: 408mm
x 3
