Main Shaft bearings???!!
  • Main Shaft bearings???!!
    So, one of the main shaft bearings on my 700 is a bit notchy. Got some replacement bearings from rc-bearings.co.uk and managed to tap the old ones out. However, I cannot for the life of me get the new ones in to the metal bearing holders. I have even put the bearing holders in the oven at 100 C for 15 minutes and the bearings in the freezer in a ziploc bag and still can't press them in
    Anyone got any ideas how I can get the damn things in!!
    Gerd
    2 x for me
    Put some 'Soft jaws' in a vice, and squeeze them in.
    (You did order the right size didn't you?)
    Henseleit TDR V-Bar x2
    SAB Goblin 700 V-Bar
    T-Rex 700e DFC V-Bar
    Synergy N7 V-Bar OS105 HZ-R
    Synergy E7se V-Bar
    Synergy N5c FBL V-Bar
    Gaui NX7 V-Bar YS91 Tareq SRX
    T-Rex 550 E FBL V-Bar
    Gaui NX4 V-Bar
      on my 700 i had to heat the block up until it was very hot
      i used a hot air gun
      the bearing felt ok once cooled down but as i had just sold it i never found out if it was any good
      Hirobo Turbulence D3
      1/4 scale Vario Bell 47 G3
      1/3 scale Vario R22
      2012 LHC Scale Cup Judge
        Yep, definitely the right size. Will have another go tomorrow, try heating them up even more and se if I can get them in!!
        Gerd
        2 x for me
          Replaced the bearings on mine lots of times and they normally just press in,i just press them in a vice
          Glenn
          logo 600se
          700 N dfc
          700 dfc
            Bearing blocks hot and bearings cold,something protective (I use a couple of bits of plywood) on the jaws of the vice and press it in.
            Just make sure its aligned 100% square before you do.
            Blade mCPX - now Version 2
              2 socket spanner sockets and a G clamp keeps it straight.. some vice(s) don't run true
              PGK
