Replacement feathering shaft bolts (TRex 700)
  • Replacement feathering shaft bolts (TRex 700)
    For anyone who has heard about the small handful of cases of TRex 700 feathering bolts snapping in flight, these might be of interest (at the bottom of the page):
    Special Hardware
    They are claimed to be 3 times stronger than the standard kit bolts. I reckon I'll get some when they are stocked by someone in the UK.
    Feathering shaft bolts shearing in flight?!
    Wonder how long it will be before the 'new bolt upgrade'
    x 3
      Nice Ski trip JSQ nothing broken?
      I'll remember to stand well back next time you fly, until you get these new bolts then! :~)
      L̶y̶n̶x̶ ̶3̶8̶0̶X̶L̶ -
      Black Hawk (Helipro) 450
      Blade mSR
      Blade 130X
      Trex 450 SE
      R̶a̶p̶t̶o̶r̶ ̶5̶0̶ ̶T̶i̶t̶a̶n̶ -
      Trex 600 LE
      Trex 500 - crashed pondering repair !
      + Planks too I'm afraid ......
        Great skiing and all bones intact. I don't know... I go away for one week and suddenly you're flying inverted and Cupracing is doing Piroflips! lol.
          There's been a bunch of people talking about it here for example but I've read a few others:
          Spindle bolt sheered off - was total loss - HeliFreak
          I'm sure it's a pretty rare occurrence but seeing as these bolts are only $9 for a set of 6 it's probably worth getting some.
            Another case for buying some unbrako or other name brand socket hex from your local engineers supplies.
            I wonder if this has ever happened with plastic main blade grips? maybe its the same story as the tail grips...
            Some folks don't like the plastic grips after problems with early kits. I've been running my two 600n at 2100 and 2150 with plastic grips without issues.
              This is specifically about the TRex 700 and the bolts used on the feathering shaft are a custom designed shouldered bolt so you can't just buy one off the shelf.
                Thanks for the heads up on these, hopefully FL will get some in soon.
                Henseleit TDR V-Bar x2
                SAB Goblin 700 V-Bar
                T-Rex 700e DFC V-Bar
                Synergy N7 V-Bar OS105 HZ-R
                Synergy E7se V-Bar
                Synergy N5c FBL V-Bar
                Gaui NX7 V-Bar YS91 Tareq SRX
                T-Rex 550 E FBL V-Bar
                Gaui NX4 V-Bar
                  Both Fast Lad and Midland Helicopters are agents for Lynx, so hopefully they will get them in soon.
                  Proud Sponsor/Pitman/Servant/Slave to Bart101s fleet of Outrage and Avant helicopters
                  Bart101 suffers from a medical condition called "Compulsive Inpulsive HeliAddict"
                  sigpic X3
                    Dont know about the feathering shaft bolts but the frame screws are great. I have just replaced a set on a heli I was fixing for someone, not cheap but you WILL be able to unscrew them when you need to as the head of the screw is deeper than the standard align ones.
                    TDR (in progress)
                    SAB Goblin 700
                    Vibe 90SG Vibe 500E
                    Kalt Baron30
                      I also bought a set of Lynx frame bolts. First impression was that of high quality. Then I found that I couldn't engage the tip of my hq hex driver in many of the bolt heads. The hex holes were too small. Tried 2 other hex drivers and same deal. FL replaced the faulty bolts but still. Have now swpped out all of the OE frame bolts. Suspect that the bolts could start to seize due to galvanic corrosion further down the line though, since the screws are ss and most of the frame parts are aluminium.
                      nCPxbl|nCPxdbl|mCPx|mCPxbldfc|T150dfc|130Xdfc|180cfx|B400dfc|T600ESPdfc|T700Ndfc|G700dfc|DX9|PL8|BLHeli
