Guys,
Two questions, please:
many thanks,
Si G
- I need to swap out the starter shaft on my 700 after snapping it at the coupling end. I think the easiest way to drop it out is to remove the undercarriage, carbon base plate and engine+fan shroud. The shaft should just drop out then, yes? Then refit is the opposite of removal. Any better ideas?
- Any tips on tuning the OS 91 HZ Pumped engine? I don't want to run too lean, but don't want to waste fuel or have sub-optimal power either. Clearly I can#t feel the baseplate (the pump is in the way) so is there any good advice to get the last bit of tuning right?
many thanks,
Si G
