700 sudden tail wag?
    I still have a tail wag guys!!
    PROUD OWNER OF 4 EDDIE GOLD STARS!!!!!!
      Heli is happy......lol
      HAve you made sure the servo is not binding in its travel, i.e. the tail slidder is not running tight on the output shaft
      James
      Sponsored by
      Align-Trex.co.uk
      Optifuel/optipower
      MKS servotech
        Yeah, happy heli.... sad pilot!!LOL
        Everything is running smooth as silk, i'm baffled and just hoping its not a 3GS failure
          99.9% of the time it is mechanical mate, check all your connection though and check the pad, make sure the gyro is nice and secure
          James
          Sponsored by
          Align-Trex.co.uk
          Optifuel/optipower
          MKS servotech
            Another check on those boom supports
            wouldnt go a miss either mark.
            Been there myself only takes one to be
            slightly loose and thr heli lets you know
            about it.
            Martin
            Aka RCSlopesurfer
              All good mate.... been right through it but i may have missed something.
              Its bound to be something simple....
                Dont know if its been suggested Mark but have you overtightened any of the screws on the tail assembly causing binding? Disconnect the pushrod from the tail and make sure its silky smooth.
                Adie, we all stopped putting posters on our walls years ago! (Are yours Take That ones?)
                  about it.
                  Good shout that. Happened to me. In fact I'd bet that was it.
                    Ah yes the pins can shear in the supports and that would cause a wag, check the supports
                    James
                    Sponsored by
                    Align-Trex.co.uk
                    Optifuel/optipower
                    MKS servotech
                    • #25
                      James
                      Sponsored by
                      Align-Trex.co.uk
                      Optifuel/optipower
                      MKS servotech
                      • #26
                        Or was it a boom shapped like a banana[ATTACH]12293[/ATTACH]
                        Dont get me started on you...... LOL!!
                        • #27
                          My money is on the tail blades in the wrong way around
                          hope it's fixed for the weekend
                          Cheers Paul
                          Citizen #42
                          • #28
                            I've just put the 3G on my Trex 700. It flew great apart from a slight bobble at high speed. Then last sunday the tail started twitching (10 degree kick.). It seems the align pads are next to usless, so I've been advised to put a piece of 3M double sided foam tape, a plate then a sparton pad. Apparently the 3G unit likes to be firm. So I,m following this thread with interest.
                            The other things I've done. Changed rudder servo from 8900G to the Align 650., and a bigger TX pack 3800 and a set of Edge flybarless blades
                            Align Trex 450pro Vbar
                            Align Trex 550 fbl Vbar
                            Align Trex 700 fbl Vbar
                            Logo 6003D fbl Vbar
                            Blade MPCX Version 2
                            • #29
                              Boom supports are all good, learned that from Petes and Martins troubles of old.
                              Everything is nipped fairly tight on the tail but all seems smooth and ive had it apart so many times now it would have flagged i reckon.
                              My 600 is running the same tail set up and all good.
                              • #30
                                When did you last change your engine bearings ???
                                Every time my bearings are on there way out I get a tail wag.
                                I'd put money on this being your problem mate
                                these new mems sensors pick up the slightest vibe problem
                                hope this helps
                                by the way my original hz bearings lasted 60 odd flights , this latest set less than 20 But it had not been used for a couple of months which probably didn't help.
                                MARK
                                LOGO 500 V-BAR v5.2
                                GAUI X4ii
                                PROTOS 500
                                MINI PROTOS 6S (stretched )
                                GAUI X3. 6S
                                JR DSX12
                                14SG S-BUS
                                proud owner of 2 x EGS
                                www.bmmfc.com
