RCE G600 Gov
  • RCE G600 Gov
    Having some probs with the RCE-G600 governor installed on Trex600LE
    Been having the same problems since the start. Setup the governor settings on a spectrum DX7 with the mixing menus, on the GEAR channel of the receiver. i.e. one mix for normal, one for idle 1 and one for idle 2.
    Normal mode has a headspeed of 1900 and idle 1 + 2 are 2100.
    When i have the governor off the engine and heli behaves normally. When i turn it on, the engine cuts suddenly and intermittently, causing the tail to flick fairly violently. The headspeed seems to come up to speed, but intermittently cuts out throughout the flight.
    I have a DS610 servo attached to the governor and it is setup with all magnets installed correctly.
    The video below shows what's happening. I flicked on the governor just before liftoff and you can hear it cut quickly. After the third time it cuts, i turned off the governor and flew around on the throttle/pitch curves i've setup.
    [ame="http://www.youtube.com/watch?v=2g8_S2FzmAE"]YouTube- Trex Gov_0001.wmv[/ame]
    Just wondering if anyone has any ideas what this is??
    Cheers!
    If everything seems under control.........you're not going fast enough
    perhaps you have a faulty sensor?
    Goblin 700
      Turns out the sensor wasn't positioned properly, moved it a little bit and it appears to be working perfectly now...................so far!
