Best 700 canopy mounts?
  • Best 700 canopy mounts?
    Seems pretty tricky to remove the canopy without burning your fingers on the muffler so I think I'm going to get a set of these RC Booya quick release canopy mounts:
    Fast Lad Performance
    Has anyone used them? Is there anything better out there?
    Yep, fully recommend RC Booya, I have them on my 500 A++
    TRex 500 ESP VBar
    Flybarless is more
      I really like the RC Booya mounts. Used them on my 700 for a year but recently the threads almost simultaneously stripped. I'd go for the Quick UK variety
      Midland Helicopters Ltd Quk_Align
        Have you got the new quick release ones? I've got the older version on my 500 as well and it works nicely -just wondering how this latest version is.
          Quick UK for me on 600s and 700
          TDR (in progress)
          SAB Goblin 700
          Vibe 90SG Vibe 500E
          Kalt Baron30
            Ooops, guilty speed reading again...you are right the 500's are not quick release so I can't really ffer a valid comment.
            Good luck..
            TRex 500 ESP VBar
            Flybarless is more
              Maybe I'll get the Quick UK's instead -they're a third of the price for starters. Can anyone tell me if it's actually easier to remove the canopy with these? The stock mounts are very tight.
                Re: Best 700 canopy mounts?
                Having had both quick uk and booya without a shadow if a doubt booya will be on my machine any day as they are loads better quality.
                  I've got RC Booya (although not the quick release one's) on one 700 and Quick UK on the other, much prefer the Quick UK ones. And yes, easy enough to remove.
                  Nick
                  Henseleit TDR 2011 VBar 5.2, Avant Aurora, 700N BeastX, 500 BeastX
                  Member of Byley MFC & South Cheshire HeliAddicts (www.southcheshire.rcheliaddict.co.uk)
                    Which ones Ben? Quick release or standard? The Quick UK's are better quality IMO. The threads on the Booya's are a much higher pitch where as the Quick UK's are M3.
                      I've just fitted the quk ones to mine, got fed up of struggling to remove the canopy on the standard ones, quality wise they are great. £30 for a set of canopy mounts for the booya ones is crazy money!
                        Ditto. I have the Booya ones on my 600 and the QUK ones on my 700 - the Booya one are far better. I intend to replace the QUK supports as soon as I can.
                        Shaun.
                        Proud owner of an Eddie Gold Star.
                        T-Rex 450 SE V2, Maniacs, Kontronik Jazz ESC, Microheli Tail
                        T-Rex 500 CF, DS510's, Maniacs, Torque Tube Tail Drive
                        T-Rex 600NSP, Maniac 603's
                        T-Rex 600ESP, Maniac 603's, DS610's
                        T-Rex 700LE, Maniacs, DS610's, Solid-G/BLS251, ElyQ Reg
                        Futaba FF7 2.4 GHz
                        Phoenix Sim
                          The Quick UK mounts are great, there is no stressing to get the canopy off as the fixing is by a knurled screw with male thread. you simply undo the nut off the post and the canopy is free, no stressing over a spigot.
                          TDR (in progress)
                          SAB Goblin 700
                          Vibe 90SG Vibe 500E
                          Kalt Baron30
                            As the problem on the 700 appears to be with just the front ones and in particular the one by the exhaust, I put quick uk on the front but left the Align ones on the back.
                            Now should I have a massive smash I still have another complete set of canopy mounts.
                            Member of Mk Heli Club
                              I like Evo Andy's idea.
                              However, I have used a range of canopy mounts and just returned to using standard mounts for a number of reasons:
                              1. used in conjunction with the little metal clips, you go through less canopy rubbers than you do with any other form of screw mounts, Quick Uk etc.
                              2. No threads to strip.
                              3. Cheap to replace in event of crash.
                              They don`t look as good as after market ones, granted, but I`ve never had difficulty getting them on and off (just ream the canopy hole a fraction bigger if you do). Simple and very effective in my opinion.
                              matt
