600 Boom Support Brace..
If all you are after is a brace between the two support rods then in the first instance it would be easier and cheaper to make your own. You can do this with a cable tie and some heatshrink or a piece cut from an old support rod. Once you have it all done up, and shrunk the heatshrink if using that, hold it in place with some super glue.
Having just saved you £10.00 can I split it with you! lol.
x 3
