600 Grip/head washers..
  • 600 Grip/head washers..
    Has anyone seen if/where you can buy the thin washers that are in the 600 main grips seperately?
    x 3
    These are the ones, cant even see them on Modelfixings
    x 3
      Sacko
      Is that diagram an old one? The T600 blade grips now only use X1 10.25mm X 14mm X 0.8mm washer.
      http://www.fast-lad.co.uk/store/manu...ex600nhead.gif
      They come as a set of three in new thrust washer kits.
      Hope that helps.
        Cheers, not sure tbh. Its from the NSP manual on helifreak that I saved a while ago.
        Are there any difference between the metal and plastic grip bearing/washer assembly?
        x 3
          Only got the plastic heads, so can't compare for you
