Numpty TREX 700 Tail Boom Question
  • Numpty TREX 700 Tail Boom Question
    Guys,
    I need to swap out the tail boom on my new-to-me TREX 700. I've seen the finless bob video on helifreak.com so I know how it goes together and I'm certain that the torque tube will be fine, however I'm not sure if the rubber grommets that sit over the bearings will need replacing and can't seem to see them referenced as spares on the fast-lad website. Am I missing something or do they normally come supplied with a new torque tube or tail boom?
    Also, Bob says to use pure silicone oil to ease the rubber grommets down the tail boom without them jamming. The silicone oil won't eat rubber he says. Can anyone point me in the right direction for a suitable oil or can I just use a bit of vaseline, thin motor oil or olive oil?
    cheers!
    Si G
    The rubber grommits are a total arse IMO.
    You have to buy the Torque Tube bearings which come with the supplied rubber bearing cover.
      thanks, mate. What threw me here is that the same bearings come supplied with the TT. £6.93 though!
      Si G
      Any ideas on lubricant anyone?
        What makes you think that Tim?
        My understanding is they simply provide support and the uneven spacing prevents resonance which seems logical to me. but I stand to be corrected of course.
        TDR (in progress)
        SAB Goblin 700
        Vibe 90SG Vibe 500E
        Kalt Baron30
          I mean its a total arse having to buy the complete bearing set for the sake of a 60pence rubber grommit that you actually need Rob.
          Hence after every crash I have I rip the rubbers out of the bent boom before I bin it.
            point taken Tim
            Its been a long day and my old brain is running a little slow
            TDR (in progress)
            SAB Goblin 700
            Vibe 90SG Vibe 500E
            Kalt Baron30
              Si G
              Si
              I just use a tiny smear of 3 in 1 oil on both bearing holders and just give them a gentle push into the boom horizontally.
              Used this method with all my tt models with no problems.
              MARK
              LOGO 500 V-BAR v5.2
              GAUI X4ii
              PROTOS 500
              MINI PROTOS 6S (stretched )
              GAUI X3. 6S
              JR DSX12
              14SG S-BUS
              proud owner of 2 x EGS
              www.bmmfc.com
                Cheers. I don't have any 3 in 1 so I'll use some other thin oil.
                Si G
