still no mid range :(
  • still no mid range :(
    i still cant get any midrange power, any time u load the head it just kills the headspeed, so much that my ely q with a os50 feels like it has more grunt!!!!!!!!
    its a os 91 cspec with a omi pumped carb, running 30% rapicorn, align gov teamed with a futaba 3152 running at 6v set at 80% on the atv
    top end power is mental, climbs like a rocket, but the moment u even load the head its just drops away
    my mixture needle is at 3o'clock on the engine, else its wont idle
    if i wind the mid range out is a bitch to spool up with now pwer, lean it and it spools up ok, still loads of smoke, but still no power in the middle, lean out more, spools up even better but still no power in the middle, got curoius and checked to see how far in i actually got before i cld spool up, i was just under a quarter turn out
    surely that cant be right?
    Well, to be honest, I aint really got a clue.
    But Ill have a wild guess anyway
    If you changed the main gear and or pinion and had a slightly slower head speed wouldn't that reduce the load on the engine and make it less likely to bog down when stressed ?
    Like I said I aint really got a clue. Just bumping ya thread
    Graham
    Phoenix, DX6i.
    x2
      but then id loose power overall??? im only runnign at around 1950rpm, the top is wicked!!!! mid a shite
        Does knobody know?
          try richening the top end a bit, then leaning the midrange a bit
            Ive tried everything, even went bk out to factory setting and started again, there just nothing in the mid, full pelt climbs are wicked, inverted full pelt is wicked, any thing else i going shit, i think im gonna hang it up till i get a new engine for her, and stop wasting the fuel
              Sounds like it could be a tired ring Pete
                As far as i know its almost brand new lol
                  Are you absolutely sure you're using the correct needles. . . . other people have been confused before about which needle is the high and which is the mid, check the manwell
                  Janek
                    I havent got the manual lol rob lent me the engine, so im working it as the mid is the smaller of the 2 needles
                      yeah the small one is the mid on my os91hz default is 2 turns out on each
                        manual is here http://manuals.hobbico.com/osm/91sx-h-spec-manual.pdf
                          Think im about 1.5 out on the main and im a quarter/half out on the mid, anything higher and its a pig to spool up
                            have you removed the needles to check for any crap in the carb?
                              Am gonna have a tinker tonight, or tomorrow, need to change then bearing on the main shaft, so ill check it all at once, cld just be a faulty pump, coz sometimes my rpm hunts, cld be a split clunck
