Threadlock or not
  • Threadlock or not
    Hi
    I took the 700 out today, Im determined to get used to it .
    After a couple of tanks, I noticed fuel dripping out, on closer inspection the needle valve assembley had come loose.
    Should I use threadlock on it to stop this happening again, or will the heat of the engine just melt it ?
    regards
    Sean
    Retired
    There should be no need to use any threadlock on any part of the engine.
    Member of Mk Heli Club
      No threadlock, just tighten it up
      Threadlock can become a lubricant when heated
        I think your find that loctite is used as stated in the OS50 Hyper Manual...
        http://manuals.hobbico.com/osm/50sx-h-hyper-manual.pdf
        NOTE
        As the idle mixture control screw is installed with LOCTITE, it may initially feel stiff, and it is suggested
        to use a littli larger screwdriver. The screw can be
        turned only 90 degrees either way. Do not force to turn
        further, or it may break or cause trouble.
        Mike.
          Hi Mike
          It wasnt the mixture screw, it was the complete needle valve assembly
          dunno if this would make a differnce, I have tightened it without threadlock, but i will keep a close check for the next couple of flights.
          My main concern would have been melted threadlock getting to the fuel supply whilst flying
          Many thanks
          Sean
          Retired
