T-Rex 700 Nitro: go for Mod 1 or std main gear?
  • T-Rex 700 Nitro: go for Mod 1 or std main gear?
    Hello,
    quick question, I just started putting together a 700 LE (YS 91 SR / Hatori SB-19 FH) for 20 % nitro.
    Now I've got one Mod 1 main gear / pinion set available. Should I use it, or stay with the stock main gear? If the problems with the standard gear are now solved by Align, I'd rather stay with the stock one. On the other hand, this heli will do many many tictocs next summer :-)
    Any would be opinion appreciated
    I think the general opinion is go straight for the mod 1 gear, specially' if you have one to hand
    Regards
    Sean
    Retired
      if you have one then you might aswel put it on, but the -1 gear has sorted the issue for me.
        I thought the le had the upgraded gear... Can anyone clarify?
        PROUD OWNER OF 4 EDDIE GOLD STARS!!!!!!
          Im giving the -1 gear a go, if i can strip it the mod1 mircoheli is going on it
            the -1 is the replacement for the standard gear, as is now supplied in all kits from new, not known anyone have any probs with this gear that i have heard
            James
            Sponsored by
            Align-Trex.co.uk
            Optifuel/optipower
            MKS servotech
              OK, thanks, all!
              I think I'll give the -1 (standard Mod 0.7) gear a chance.
