Thrown in at the deep end.
    you will need another channel to run the align gov as you can only set it with endpoints, if you want to keep the dx6i you'll need to buy a revloc as they allow manual settings, congrats on the new heli though i'm sure you'll love it
      Guys another question for you. Im gonna order a new TX today or tomorrow, was gonna go for a DX7 but have stumbled across the Aurora 9. Anyone have one or can advise me which to go for ? The Kit bundle of TX/RX and 4 servos is a little more for the Aurora buy about £30 from what i can see. All my other heli's use Spektrum recivers but im not too worried about that if i went for the Aurora as i will just keep using my DX6i for the others. But obviously if i got a DX7 it can all be on one.
      Matt
      Trex 700le, 600N, 250SE
      Beam E4
      Blade 400, 130x, MSR
      Walkera 4#3b
      Parkzone Corsair + Micro Mustang
        Originally posted by Snowsurfer View Post
        Just received a very unexpected present from my girlfriend. Its a Trex 700 Limited edition !!!!!!
        I love your girlfriend! Hang on to that one - they don't come around often!
        Enjoy the build - you'll have lots of fun and don't be afraid to ask what you may see as dumb questions. You'll get honest answers here for sure.
        Martin
          hi i would personally go for the dx7 set instead of the hitec set. there is nothing wrong with the hitec set but id say its pointless when all your other helis are on spektrum its just better to use one tx for all your models.
          mark
          MARK
          MCPX BRUSHLESS
          LOGO 400 V BAR
          T REX 550 V BAR
          T REX 700 LE
          JR DSX 12
          JR DSX 11 THE UGLY B*S***D
            Top prezzie mate..... lucky guy.
            You will love the 700LE.... its awesome and works so well straight out the box with all the included gear. Mine is totally stock and runs a 91HZ non pumped and hatori pipe.
            Cheapish servo on the throttle is fine... it needs to be digital though.
            Get a DX7 IMO.... does what it says on the tin and others will be able to help with its set up if needed as so many people use them for good reason.
            Lush heli..... really can't fault mine
            PROUD OWNER OF 4 EDDIE GOLD STARS!!!!!!
              First build problem
              On page 10 of the manual it shows a frame mounting block at the back that holds the tail control arm. It shows it as if the notch should fit into the hole in the frame. Mine wont, its only possible to fit it by installing it with the notch facing inwards on the heli? The physical hole in the frame wont allow it in.
              Matt
              Beam E4
              Walkera 4#3b
                Here is the offending piece ive put in on the only way it will fit, but the manual shows the lump at top should be facing the other way into the frame.
                Matt
                Beam E4
                Walkera 4#3b
                  Thats correct mate... goes on the inside
                    sorry mark, disagree, you need to put it in the other way mate, if it is tight just file the piece down a bit, or the frames a bit, they can be a bit tight sometimes
                    James
                    Sponsored by
                    Align-Trex.co.uk
                    Optifuel/optipower
                    MKS servotech
                    • #25
                      No your right mate.... just had a look at the heli, thought he meant the block on the outside
                      Looked right by the piccie but it is the wrong way round
                      • #26
                        As not sure on which engine to get as it says the 91H or 91HP ??
                        Any advice will be great as im very confused and excited...
                        Thanks in advance
                        Buy the 2nd hand YS 91 st just advertised tonight, it's what i'm using &
                        it is ballistic on 30 %
                        Martin
                        Aka RCSlopesurfer
                        • #27
                          I wouldn't trust a 50 on a DX6i that alone a 90 machine.....
                          the battery set up on the DX6i is enough for me to say upgrade the Tranny and fit a bloody good RX
                          Mark
                          www.uavaerialservices.co.uk
                          BNUCs - Operations certified
                          CAA - Permit for Aerial Work
                          • #28
                            Thanks guys i will have to file it down then as its never gonna fit, hole in the frame is prob about 1-2 mm too small.
                            Matt
                            Beam E4
                            Walkera 4#3b
                            • #29
                              Ordered up a DX7 ,MP6 90 Size Curtis Youngblood pipe and a O.S. MAX 91HZ. Have to wait for bits now until i can build anymore.
                              Matt
                              Beam E4
                              Walkera 4#3b
                              • #30
                                What plugs do i need for the OS Max 91HZ??
                                Im gutted today as i ordered the extra bits i needed on sunday next day delivery, so expected them to be sent out today. Maybe they are not so "fast" after all
                                Matt
                                Beam E4
                                Walkera 4#3b
