burnig up plugs OS 50
    Originally posted by Geek View Post
    Think there is a few things to do
    It's over reving
    might need the fuel line changing in the tank ( the clunk ) that's the think you hear when moving the heli around clunk clunk
    I would get a governor for christmas
    ha! now i get it
    i have a governor but no 7 channel Tx as of yet, thats what i am getting for chritmas .
    the clunk is moving about the tank when i invert it it is getting down as well.
    i will lower the curve tomorrow and give it another go tomorrow before i do an engine out. i am on a 4 week holiday so loads of time .
    Trex 700N LE FBL
    Trex 600N DFC, OS 55HZ, Vbar
    Trex 600e FBL, 12s Scorpion 630kv, Vbar
    Trex 500e FBL, Scorpion 1400kv
    , Spirit
      I have heard before of the tank having a split in it causing it to lean out once the fuel drops below a certain level.
      So that would suggest an engine problem then??
        Another thing that can blow plugs is duff fuel & clunk lines.
        Small bits of it can get into the engine & smash a plug.
        I change all mine every two months or so.
        David
        Happy Landings.
        David
        Raptor 50. OS50
        Mcpx
        Blade 130x
        Goblin 500
          so after doing a few changes,
          New header tank,
          OS bubble less Clunk,
          all new fuel line filter.
          i head to the filed, give it a start, to small firings and i loose full compression, the starter was spinning away with no resistance from the engine, quick check to see oneway bearing ok? yes....
          so i pack up head home engine out and see whats been causing my plugs to go.
          so guys any advice please,
          i think my engine serioulsy over reved overheated etc... etc...
          is it worth putting a new piston and ring to see if it will work or bin it, a new sleeve and its definitely the bin due to the sleeve price....the sleeve seems good but you never know until it will fire up.
          i do have spare engine so please advice so i dont do this again.
          Sav
          Trex 700N LE FBL
          , Spirit
            Is that a hole in your piston?
            Henseleit TDR V-Bar x2
            SAB Goblin 700 V-Bar
            T-Rex 700e DFC V-Bar
            Synergy N7 V-Bar OS105 HZ-R
            Synergy E7se V-Bar
            Synergy N5c FBL V-Bar
            Gaui NX7 V-Bar YS91 Tareq SRX
            T-Rex 550 E FBL V-Bar
            Gaui NX4 V-Bar
              Sorry to hear this.
              Think I would strip it and check bearings as it might be bearing that has done the damage. You might find that there are still alot of spares to be had from that engine
              then it's up to you about cost of rebuild or new or secondhand.
              All the best
              Cheers Paul
              Citizen #42
                New header tank,
                Sav
                Looks like a wacking great hole in your piston... that would account for your lack of compression.
                Futaba 9CP & 10CG
                  I had that happen on an old OS50 SH-X, though it was about two years old and had well over 150 flights on it, mainly mild aerobatics and some 3D.
                  Like a lot of people have said that mid point on the throttle curve is way too high especially since you're not running a governor, it needs to be about 30-40% depending on the blades/heli mechanics etc, just enough to maintain headspeed at zero pitch, 80% is more like an electric throttle curve.
                  Like Geek said, strip down the engine, and make sure there are no bits left at all in the engine, the last thing you want is to put a new piston, liner and ring in and have it all get scored.
                  Current kit
                  Evo 50
                  T-rex 500FG night setup.
                  T-rex 700N pro
                  T-rex 450 pro
                  10CP
                  Frankenstarter (dynatron)
                    yes its a piston melt down
                    Trex 700N LE FBL
                    , Spirit
                    • #25
                      yes i went from an electric to nitro so thought it would be the same theory, quite an expensive way to find out not..
                      when you say 30-40% do actaly mean 40% max in idel up?
                      thanks a lot guys
                      Trex 700N LE FBL
                      , Spirit
                      • #26
                        In either Idle 1 or 2 when the pitch is at zero degrees (midstick on a 3D pitch curve), you want roughly 30-40% on the throttle curve.
                        Mine is like this on my Evo 50
                        Pitch ____Throttle
                        +100_____100
                        +56______72.5
                        +27______50
                        0________40
                        -27______50
                        -56______72.5
                        -100_____100
                        Obviously 7 point curves, the pitch curve corresponds to +100 = full pitch, 0 = zero pitch, -100 full negative pitch.
                        Current kit
                        Evo 50
                        T-rex 700N pro
                        T-rex 450 pro
                        10CP
