Building 700 LE. What fuel 15% or 30% ???...
  • Building 700 LE. What fuel 15% or 30% ???...
    Hi guys,
    I am building a 700 LE which I find quite easy compared to the 450 Pro I just finished, nice to have BIG parts!
    Just a question, I am running Coolpower 15% in my 600 NSP which for me is fine I guess, I am a sport flyer looking to move into 3D.
    Would you recommend starting with 15% on the new 700 LE or straight away start using 30% to break in the engine with that fuel?
    Because I will probably end up using 30% when my flying develops.
    Is there quite a performance hike from 15% to 30% ?
    Looking forward to your thoughts/recommendations....
    Ciao,
    Robin.
    Align T-Rex 700 LE
    Gaui Hurricane 550 CF
    Align T-Rex 450 Pro
    RC flying is harder than real flying.....
    I was always tought to use the fuel your going to use for running in. 15% is very low and most modern engines are designed for 30% if cost is a factor go for 20% if its not then go straight to 30%
    Edders
    Don't argue with idiot's on forums; people watching may not be able to tell the difference.
    Sponsored by Midland Helicopters, CSM and OptiFuel.
      Hi i could be wrong but i always thought if you want more power you use more nitro. But if you are happy with the way your motor runs on 15% why spend more money for 20% or 30%. There could be a good reason for using 20% or 30% and if so can someone explain.
      I am still learning and i am using 12% optifuel enough power for me at the moment. Motor runs lovely smooth and responsive it's an os50hyper. would like to hear some of your thoughts.
      Del
      Velocity 90 FBL Beast x
      Outrage velocity 50 nitro,
      Beam E4
      Futaba 10 CG
        30% is an expensive way of running a 90 unless you fly the pants of your machines then 20% is more than fine,i use optifuel 20 on my 600/700 and its fine for all but the top flyer's IMO and at i think £8 a gallon more it soon adds up.
        Glenn
        logo 600se
        700 N dfc
        700 dfc
          Thanx guys,
          I'll just go for the 30%, more power and the engine runs cooler.
          The extra price for the fuel is not an issue for me.
          Robin.
          Align T-Rex 700 LE
          Align T-Rex 450 Pro
