Hi folks
Need some advice from the Trex 600 guru's on here.
Never owned one before and I am currently setting my new to me sport up (thanks Martin) with the recommended upgrades (thanks Brian).
My question is regarding the metal washout.
I have bought the super pro washout arms which have the ball races in the 'Y' arms and also the metal washout base.
However, looking at the metal washout base already on the Heli, it looks much more substantial and also has a brass sleeve to run up the mast. This I thought was the preferred method of construction but my new washout base does not have the brass insert nor is it as 'chuncky' as the old one.
Could any super pro users tell me if this is the standard and is okay to use or should I put the new arms on the existing metal base?
New washout base is this one: Fast Lad Performance
Is this the super pro standard one?
Any advice gratefully received.
Mark (Trex 600 virgin)
