Finally got her flying well - only took 3 crashes (one hardware failure - unit replaced by FL - thanks)
But two crashes because the links to the head were too short. 70mm in total with a gap of 61.5mm between the plastic links. Twice the links popped off following aerobatics. Solution - 75mm links and now all is fine.
I could have lengthened the links from the servos to the swash, but then they would have risked popping off also.
Interesting that the manual with the head conversion gives no info on link lengths. Still alls well that ends well.
