Which mixing arm hole?
  • Which mixing arm hole?
    I am using Sonix metal mixing arms on my 600N (I assume that they are a direct clone of the Align part). At the end of the arm that links to the blade grip, there is a choice of two holes for the ball link -which one will give me faster cyclic? And what other effect will it have if I move it -will I lose a bit of stability etc?
    This is a very similar question so i might as well put it in the same thread -there's 2 holes on the flybar holder where I can mount the mixing arms -what is the effect of using either of the two holes? (again it's a Sonix clone part)
      Well I think I have found the answer to my 2nd question at least -mounting the mixer arms on the inner hole will give faster cyclic (and I assume a slight loss of stability). Is that correct? Is the difference quite noticeable?
