Can anyone assist please, I am currently building my first heli, a TREX 600NSP and would be really gratefull if anyone could post some picyures of the location of their governor, 2in1 regulator, battery, ignition unit, etc and the interconnecting wiring from these units and indeed the servos. Im going to place the gyro behind the mast. I appreciate the manual indicates suggested locations, however, there is no substirute for some as builts to have a look at. Ive really enjoyed the build so far, frames are built, servos about to go in, im not the most confident builder, bit nervous as this is my first build, this website has been really helpfull to me I have to say. Ive picked up so many tips and advice. Many thanks in advance to anyone that can help.
TREX 600NSP wiring layout
My Trex600 build article might help here.
It's not the NSP, but the original Pro version - basically the same heli at a lower spec.
RobTeam Align, Midland Helicopters, Optifuel, Cyclone Blades, Scorpion Motors, Thunder Power, Savox Servos, JR Propo
| 3D Championship
I should add that in my article I didn't install the governor, that came later.
The governor article is here.
The governor unit was mounted on top of the nose-piece, in front of the receiver (I stuck some more velcro on the nose and on it went).
| 3D Championship
it won't win a beauty contest...
some gyros don't like the gyro mount on top of the servos. Alternatively put it to the tail, but it's annoying when I have to change the umbrella gear.
I'd recommend to use push/pull linkage on the throttle. Otherwise, the carb barrel may get stuck one day. And it can be a nasty surprise when I don't expect it.Attached Files- IMG_0596.jpg (235.2 KB, 38 views)
Last edited by GravityKills; 04-06-2009, 06:10 PM.Woohoohoohoohoohoohoohoohoohoohoo -Barbra Streisand
