Hi guys
When installing the fan onto the engine last night I found that it was a very tight fit and I ended up almost pulling it on by tightening the engine crankshaft bolt. I had totally removed the fan retaining screws that tighten the fan onto the crankshaft.
Is this normal? I'm a bit worried when it comes time I need to take it off.
How do you guys remove yours? Is a puller available?
Cheers.
Cheers.
