Many of you may be aware of this Problem that being discussed World Wide on other Heli Forums
When you move the main shaft from the top of the head you notice a significant amount of play between the main shaft and the bearings.
The shaft's diameter is to way to small as it is 9.95mm and the Main Shaft bearings are 10mm in measurement.
As yet Align TW / UK & USA have ignored E/Mail’s from ESP Owners including mine.
Asking them to simply make the main shaft diameter to 10mm to eliminate play.
This amount of play between the main shaft and the bearings can also be seen on U Tube videos
[ame="http://www.youtube.com/watch?v=sNqAvQB4H1A"]http://www.youtube.com/watch?v=sNqAvQB4H1A[/ame]
If you also have this problem please e/mail them and they may realise there is a problem with the ESP
