Peeved
  • Peeved
    Well a couple of week's ago I had a slight bump with the NSP - well more like a head on smash!!!
    So repaired it then went for a flight last weekend - only to find that a small crack was in the tank and the YS working off pressure and no pressure and it was just not worth it. So that ended that weekend.
    New Replacement tank in all new fuel tubing and off I went today.
    Started it was running lean on idle, richened it up a little. Spooled it up and it the engine leaned right out and head went nut's - then re-looked at the needles again. Spooled up again and again it leans off.
    Okay back to pit's - checking pipes, all over looking for any clues. Fuel all over the tank on the top. Can't see anything but what I can see is that the tank isn't getting pressure. So I start looking at the oneway valve its all looking okay.
    Attempt no. 2 - tried starting it won't - so I take the plug out - baring in mind it was a brand new plug its fried, so in goes another new one.
    It starts - This time its better - but back to land and looking over I can see that that tank is not getting much pressure in it.
    Back to the pits - by this time I'm getting more peeved - was looking forward to more time in the air less on the ground.
    So decide to do a pressure test and fuel up the whole system.
    BINGO
    Found the B£$^$&*rd.......
    Align's lack of quaility checking - replaced one used tank with a tiny crack with a brand new one with a manufacturing defect in the drilling of the pressure nipple and punctured the outer wall of the nipple at the base.
    Stuart
    I know how you feel with regard to some aspects of Quality V Align........
    ONE Eddie Gold Star!
    Kinross Radio Model Flying Club
      Thats a $hit hey oh well at least you found the problem while it was on the ground back to the shop now for another new 1 (i know u will check b4 u leave )
      At least u got out
      Danny
      London model heli flyers
      I am learning all the time. The tombstone will be my diploma. ~Eartha Kitt
      Blade Mcx
      Blade 400 with 3 x hs65mg's, Gy401 with fs61bb tail, 450 canopy
      Yellow 600 nsp 451's on cyclic, 251 on tail with Spartan ds760 ,ds620 on throttle,Spectrum ar7100 + csm carbsmart
      Accu RC / Phoenix sims
      Spectrum Dx7se
      F16 edf
      Mavic Pro
      Spectrum DX8 dsmx
      Blade 230s v2
      http://pic7.piczo.com/Carpman68
      www.dannycablephotography.co.uk
        pain in the ass that like Stuart. Gonna get it exchanged?
        Lee
        Lee
        www.raptoruas.co.uk
        www.lee.rcha-uk.com
        www.gensace.de
          who did you get it from, they should replace it FOC!
            They most probably will - I'd rather not name them as I don't want them to be associated with the fault it wasn't thier fault. It was brand new in the packet - so its an Align quality issue but they as the shop get landed with having to fix Align's silly mistake - mistakes that shouldn't really happen if you did a small pressure test on every tank before final packing. May seem ott but hey its just travelled halfway round the world for nothing and cost them twice the material / labour & time etc for 1 tank.
            Stuart
              i dont think anyone would have associated the shop as being bad at least it didnt cook your engine
                Well free replacement tank arrived today from Midland Heli - old one filed under "B" for bin.
                Stuart
                  good stuff, test flying this weekend again then?
                    I only wish it was this weekend, but the misses has a girly weekend sorted so it will have to be the following. - might actually turn on phoenix, I haven't used it in months to be honest.
                    Stuart
                      Glad you have got it all sorted Stuart, hope your next flight is ehhh less traumatic
                      TDR (in progress)
                      SAB Goblin 700
                      Vibe 90SG Vibe 500E
                      Kalt Baron30
                        So do I - got really frustrated with last weekend. About to turn on the sim since doing the latest update - I hope its better now.
                        Stuart
