600 NSP Build
  • 600 NSP Build
    Morning,
    I am getting ready for the big day but I just wanted to find out what I am going to need for the big Build?
    I have got all the radio gear, gallon and a half of fuel, some good Allen/ hex drives, Swash plate levelling tool, Pitch gauge, Lock tight, Cyno and epoxy
    I built my 450 and I have watched Bob's videos.
    Just wanted to know if there was anything else that would come in handy apart from flying talent as I am seriously lacking in that department?
    Nick Greening
    Trex 600 NSP Yellow and black
    Trex 450s CF
    Phoenix
    Picco Z
    http://www.gmfg.org.uk/
    Proud owner of an Eddie Gold Star
    Link removal tool/pliers is always a very handy thing to have. Will stop ya from deforming the plastic links. Makes it easier when your setting up your linkage lengths. And if you havent already got them on the rear of your hex drivers then a tool for screwing the plastic links to the rods. It starts getting tedious after you have done a few Both these tools arnt essential but will come in very handy for future models also. Wish i had of got mine for the first model lol.
    Lee
    Lee
    www.raptoruas.co.uk
    www.lee.rcha-uk.com
    www.gensace.de
      Cable ties are a must. small ones
      Protective wrap for servo cables, double sided tape possibly, some more velcro and a big pot of coffee
      James
      Sponsored by
      Align-Trex.co.uk
      Optifuel/optipower
      MKS servotech
        Lee,
        I forgot all about then I have got some ball link pliers and they very handy.
        James,
        I have got some small tie wraps and some heat srink for the cables but I had forggoten about that.
        I was thinking of getting some of that expandable cable tidy not sure of its name...
        Nick Greening
        Trex 450s CF
        Phoenix
        Picco Z
          Ya mean spiral wrap ... maplins sell it cheaper than most model shops
          Knight 3D
            Mike, Kind of and a very good idea I was thinking of Expanding Braid 2-6mm but unlike the spiral wrap I think you would have to take the servo plugs off which is a pain...
            Nick Greening
            Trex 450s CF
            Phoenix
            Picco Z
              dont forget the a vernier gauge or a controller rod setup gauge so u can get the links nearly exact same
              Danny
              London model heli flyers
              I am learning all the time. The tombstone will be my diploma. ~Eartha Kitt
              Blade Mcx
              Blade 400 with 3 x hs65mg's, Gy401 with fs61bb tail, 450 canopy
              Yellow 600 nsp 451's on cyclic, 251 on tail with Spartan ds760 ,ds620 on throttle,Spectrum ar7100 + csm carbsmart
              Accu RC / Phoenix sims
              Spectrum Dx7se
              F16 edf
              Mavic Pro
              Spectrum DX8 dsmx
              Blade 230s v2
              http://pic7.piczo.com/Carpman68
              www.dannycablephotography.co.uk
                Carpman,
                Forgot that too I have a set of digital vernier's. Sounds like I am fully kitted out apart from the spiral wrap but I can pop in to maplins at the weekend...
                Cool Thanks
                Chaps
                I really cant wait to get my hands on this kit now.....
                Nick Greening
                Trex 450s CF
                Phoenix
                Picco Z
                  Give ya build tip... one i can think off the top of me head anyways... put the tank in as you fix the 2 frames together as its a bit of a squeeze after
                  Apart from that its a typical easy Align build, just make sure ya use loktite in all the right places and anything thats metal to plastic (not that theres much on a NSP) then use a small dab of CA.
                  Lee
                  Lee
                  www.raptoruas.co.uk
                  www.lee.rcha-uk.com
                  www.gensace.de
                    Lee,
                    Funny I was looking at the a build diary and trying to fit the tank in afterwards was odd..
                    Nick
                    Nick Greening
                    Trex 450s CF
                    Phoenix
                    Picco Z
                      good tip there Lee, but make sure it is a small dab of ca as align screws are not renound for taking out easily, metals too soft and they twist off.
                      If you use the expanding braid, I have and it makes a neat job you dont need to take the plugs off to get it over if you get the right size it will slip over, you'll need a little more in length than what it looks like you need as putting the plug through will make the ends very ragged, snip the braid of level then use a good heatshrink over the end will seal the braid in place.
                      personally not a great lover of the spiral wrap as it easily gets oil in it which is awful to clean off plus as it gets older it can go brittle, hard plastic can cut into the wires.
                      All the best
                      Tony.
                        Originally posted by Nicolasgreening View Post
                        Lee,
                        Nick
                        Yeh its the same on them all i think... 700 was like that too wasnt it Tony???
                        Got 4 tanks on the 700 now... will do the remainder of the bottle (probs another 2 or 3 tanks) this weekend then time to let rip m8
                        Lee
                        Lee
                        www.raptoruas.co.uk
                        www.lee.rcha-uk.com
                        www.gensace.de
                          Watch out for the cooling fan (plastic) being warped - mine was, so I fitted the QUK replacement. Take care not to get the magnets for the gov sensor wrong, whilst I am on the sensor, it might be a good idea to locate the ty-wrap for the sensor cable before you fit the engine and cooling duct, its a real pain otherwise.
                          I also got the RCBooya canopy mounts - good imho.
                          Have fun with the build - I enjoy that bit as much as flying.
                          Shaun.
                          Proud owner of an Eddie Gold Star.
                          T-Rex 450 SE V2, Maniacs, Kontronik Jazz ESC, Microheli Tail
                          T-Rex 500 CF, DS510's, Maniacs, Torque Tube Tail Drive
                          T-Rex 600NSP, Maniac 603's
                          T-Rex 600ESP, Maniac 603's, DS610's
                          T-Rex 700LE, Maniacs, DS610's, Solid-G/BLS251, ElyQ Reg
                          Futaba FF7 2.4 GHz
                          Phoenix Sim
                            Lee
                            Yes mate, infact with the 700 the early ones were even more of a pain cos they made the tank hole slightly too small, or the tank too big, whichever way you want to look at it. but fitting the tank as you put the frames together is a wise move.
                            Also Shaun brings up a good point about the governor sensor, I would also fit that prior to building up the frames. as it can be very fiddly afterwards. on both machines 600 or 700. I didnt use the align governor in my 700 and I had a hell of a time macking a bracket to fit the revlock sensor because it had to be 90 degrees to the frame. very hard to do with the frames built.
                            All the best
                            Tony.
                              Morning,
                              The 600NSP went together like a dream took her for her maden flight yestaerday and put 3 tanks through the motor before my fingers got too cold...
                              The only problems were getting the engine turned over at the field for the first time. I had run it in the garden the day before and it started with my starter and trusty lipo combo but typical at the field we tried 2 starters and 3 batterys.... Ended up with the lot under the bonnet of the car with the starter on the car battery...
                              The other issue was the GY401 was a bit funny with a high speed wobble but we put this down to the lean running as changing the gain doesnt help...
                              Thanks for all the help the build couldn't have been easierI really enjoyed it. I spent about 2 hours a day on it and I think including leveling the swash and setting up the head and tail it took me about 10 hours.
                              Fingers crossed I can get back down the field tommorrow....
                              Nick Greening
                              Trex 450s CF
                              Phoenix
                              Picco Z
