Friday night I was flying my knight50 in the dark, somehow you see how straight a heli flies and notice errors more in the dark as you can see the disc so well, and it was calm - which it hardly ever is at my usual exposed field in the hills.
My knight was screwing out of inside loops and flips needing right aileron correction. I know my 600npro needs right aileron corerection too in an inside loop.
Looking at my knight on the bench I saw that the pins from the head into the washout block have slipped and the washout arms were no longer in line with the blade grips. The error is the way expected - inducing some left aileron with up elevator. So that is corrected and I'll see how it flies next time out.
now looking at my 600n pro, only change from stock is quick uk swash and K&B yellow dampers (highly recomended!).
See how far off square the washout arms are compared to the grips and flybar. Surely in theory these should be parallel to the spindle and 90 degrees to the flybar. There is nothing assembled wrong and there is no adjustment available. The error is such that it would need some right aileron to correct an inside loop or flip, which is what I find flying it.
The ways phasing can be adjusted are turning the washout base compared to the head block, adjusting the washour links to the swash, or changing the position of the anti rotation post.
I am wondering if the revised elevator lever upgrade (that replaces the anti- rotation post) actually turns the swash to make a correction for this error - or offers some adjustment?
For now I have shaved some off the side of the plastic anti rotation post and packed it off the frame on one side. Moving the anti rotation post toward the left side of the heli. Not enough to correct it fully but we'll see how it goes next time out.
Perhaps someone can explain how the phasing can be correct without the washout arms at the theoretically correct right angle?
With phasing errors, if you fly the model alot then you become very proficient at flying round the problem to the point where you don't see it anymore. You notice things are wrong when you fly different models.
By the way looking at my trex450 rotor head everything looks spot on and that one does seem to flip quite straight for a squirrelly little heli.
Can tightness of the grips make a difference too? I run mine quite tight at the moment.
