Hello,
I’ve recently had a problem with my TREX600 NSP during loops and continues flips where the tail will slowly turn nose right
I thought I might be me giving the heli some rudder while in the loop or flips, so I set -35% exponential on the rudder to make the centre stick movements less sensitive but it doesn’t seem to make any difference, plus my 450 doesn't do this.
I thought about uping the gain on my gyro but i think i'm about on the limit as i get a bit of a wag when i turn back into the wind. It makes the situation worse if i lower the gain.
Is there anything obvious I should check ? I’m using a gy401 & S9254 on the tail.
Matt
Matt
