Align rce-6600 govener and dx7 settings
  • Align rce-6600 govener and dx7 settings
    Hi all
    After finally getting my govener to work on my 600NSP, I was wondering what setting you guys use for normal and idle up modes. I am running it on aux 2 on the dx7.
    There are no settings for this TX in the manual and I have no idea on how to judge headspeeds.
    Richard
    Tonight Matthew..I am going to be.. Nitroman
    Trex 600NSP
    Blade MSR
    Futaba 10C
    Very proud owner of an EGS and Platinum Gold Star
    Hi Richard
    All depends what sort of flying you do, if 3D 100-105% on the travel adjust on aux2.
    If general sports then knock it down to 95%.
    If you look in the instructions go by the JR settings.
    James
    Sponsored by
    Align-Trex.co.uk
    Optifuel/optipower
    MKS servotech
      95% on my knight gives me 2100 head speed but i guess the gearing must be different
        Normanly fly mine about 2200 ish, depending on wind conditions etc.
        James
        Sponsored by
        Align-Trex.co.uk
        Optifuel/optipower
        MKS servotech
          kin hell thats a lot ofhead speed!! having said that while im waiting for my engine the knights gettin proper setup so ill wind the headspeed up too!!
            speeds up the pitch punch, amazing what 100rpm can do
            James
            Sponsored by
            Align-Trex.co.uk
            Optifuel/optipower
            MKS servotech
              I'm running 95% on mine, tbh I can't really tell much difference going a few % either side of this.
              If you want to lower the head speed in normal mode just use prog. mix one, I have it set as follow:
              AUX2 to AUX2
              RATE: -20%
              0%
              SW:F-NR
              OFFSET: 0
              works a treat means I'm running 75% in normal mode (for taking off), if you want 3 different head speeds just use prog. mix 3 and change to:
              AUX2 to AUX2
              RATE: +10%
              0%
              SW:F-S2
              OFFSET: 0
              that would give you 105% in flight mode 2. The ATV for the governor sets the head speed for flight mode one, then prog. mix one reduces it for normal mode and prog. mix three increases it for flight mode 2
              Hope this helps
                thats fantastic greg, i was after that info a wek or two ago and now i have it thanks very much. I couldnt work out how to get 3 different headspeeds out of my dx7.
                wooooooooooooooo
                  Thanks guys.
                  Greig, many thanks for that post. Thought I could only get 2 gov settings as I use one program mix as a throttle cut.
                  Will give them a try on Friday.
                  Trex 600NSP
                  Blade MSR
                  Futaba 10C
                    No worries guys
                      Is this the right way round as i have read and set my radio with
                      aux2 -> aux2
                      rate: 0%
                      +80%
                      sw:f-nr
                      offset: 0
                      aux2 -> aux2
                      rate: 0%
                      +90%
                      sw:f-s12
                      offset: 0
                      aux2 -> aux2
                      rate: 0%
                      +100%
                      sw:f-s2
                      offset: 0
                      AUX2 to AUX2
                      RATE: -20%
                      0%
                      SW:F-NR
                      OFFSET: 0
                      AUX2 to AUX2
                      RATE: +10%
                      0%
                      SW:F-S2
                      OFFSET: 0
                      Hope this helps
                      Danny
                      London model heli flyers
                      I am learning all the time. The tombstone will be my diploma. ~Eartha Kitt
                      Blade Mcx
                      Blade 400 with 3 x hs65mg's, Gy401 with fs61bb tail, 450 canopy
                      Yellow 600 nsp 451's on cyclic, 251 on tail with Spartan ds760 ,ds620 on throttle,Spectrum ar7100 + csm carbsmart
                      Accu RC / Phoenix sims
                      Spectrum Dx7se
                      F16 edf
                      Mavic Pro
                      Spectrum DX8 dsmx
                      Blade 230s v2
                      http://pic7.piczo.com/Carpman68
                      www.dannycablephotography.co.uk
