Align RCE-G600 setting up with 9x2
  • Align RCE-G600 setting up with 9x2
    Can anyone tell me how to set up jr 9x2 to work with RCE-G600 so i can set more than one head speed and is Hitec hs5625mg compatable with unit. also on governor setting in radio only goes up to 125% and makes no differance if set at 100% when instruction say 150% for 21000. help
    and also seems to go off governor at mid point trottle curve above 50% in idle up 1 2 cant get a good head speed.
    Although I've not used the governor yet I used the info I saw on a thread in the Trex 600N forum on Helifreaks. It involves plugging the gain lead into Aux 2 and inhibiting the Aux 2 switch in the main setup, then setting up an Aux2-Aux2 mix. Mine is set up with point 0 at -65 and point 6 at -75, quite why they need to be minus I can't quite figure out but the governor is now active with Aux 2 switch at top (0) and bottom (6) with off in the middle
    Steve H
