500 banking right on its own...
  • 500 banking right on its own...
    Left trim a few clicks didnt seem to sort it... what would make the heli bank right slightly? its not major but had to keep correcting it today... hasnt had any crashes or owt...
    Servo gear lost a tooth?
    Phil
      The phasing on mine was lost (and still is to be honest) after about 100 flights. The washout guide pins have worn slightly, and the washout base also.
      I replaced the washout base and it got better, but it isn't like it was when it was new (flew dead straight!). I plan to try replacing the washout guide pins next to see if that sorts it.
      When new, there is almost no rotational movement on the washout assembly.
      | 3D Championship
        you at kesteven on sunday?
        cheers Lee
          could be if you fancy looking over it? would of asked dave today, but had to get off to see somebody.
          Any pics of what to look at and ill heve a nosey and see if i can get over to fast lads tomorow before hand
          how can i check the servo gears?
            could be an asortment of things.... remember what i said about those servos?
            pop the links off and feel them(power off) see if there's any notchiness wiggle the cyclic(on the ground)and see if there behaving
            isnt mark gonna be there?
            cheers Lee
              Servos appear to be behaving, left stick corrected it fine. pmpl marks not touching my 500 again, im not giving him chance to break it
              There is some play in the washout base to pins, would it be this? assuming this is the hub with 2 slots for the pins to sit in, and its the bottom part with the rotational play... hmmm seems like things are going to wear out before i get good at flying it!
                When you say "Banking to the right" is this in forward flight or in the hover.
                All helis bank to the right due to the drive/rotation that pitches them that way even in the hover.
                  Well done Tim.
                  This never crossed my mind as to the nature of the problem
                  As Tim says it's normal behaviour
                  Phil
                    I'm working all weekend you won't see me down at the club at all
                    Mark
                    www.uavaerialservices.co.uk
                    BNUCs - Operations certified
                    CAA - Permit for Aerial Work
                      Have I ever broken it ?
                      Naa didn't think so but can if you want me to
                      Mark
                        the heli does sit slightly banked to the right i know, always has done, so left stick on take off, but, today it started flying to the right, as if i had been putting trim in...
                        Well , better point out, ive been adding back elevator trim to counter a nose down dive for a few flights now, and just went through a few things on the fone with lee, it appears i have play in a few components, mainly the servo output shafts and washout base, which would explain the wandery behaviour... sometimes i can trim it, and by the end of the lipo ive trimmed it out again to centre. Will get it looked at before spending out on new servos though
                          Hey i never said you did... just dont think its fair to put the club chair in that position
                            Club chair ?
                            People sit on me ? naa not sure I want that
                            Mark
                              mark what servos are on your 500?!
