Hi all, i've not long finished the initial build of my pro Rex and flight tested the little beast. I have to say despite a few minor problems with my govenor failing to come online and my carbsmart sensor going open circuit i was really impressed with the heli, it went together with no problems at all, my only critisism was the questionable +-14 collective pitch, i got +-13 after some adjusting and binding checks. The handling and power to weight ratio even before djusting have put my Knight 50 pro to shame.
The heli is now partially stripped down for some mod's and adjustments, carbon tail boom, metal mainshaft bearing holders, metal hex rods in the tail mounting to get rid of the self tapping screws, metal fan, header tank and metal fin clamp. I suspect i'll be back visiting the head to get rid of some plastic parts once they wear and develope play but in the mean time I may as well get some use of them whilst their nice and tight.
The heli is is quite well fitted out, 9255's on the cyclic, gy611 + 9256 on the tail, 3152 on the throttle, a quick micro servo on my needle valve, csm revloc 20, csm carbsmart, flightpower regulator (5.1v), 2500mah evolite lipo, OS hyper 50 / mp5, radix main and tail blades and finally stubz paddles (weights all the way out at paddles).
My overall plan is to get my Rex tunned up for some aggressive 3d, fast piroflips and sustained chaos. I gave it a bit on the test flight but it just got bogged down after 2 -3 flips, hopefully some more tunning + cabsmart, cyclic / collective pitch throw adjustments and repositioning of the flybar weights will get it to perform. I had considdered going for some v-blades once i've run out of options. By the way has anyone noticed a sizable difference between radix blades and v blades? I've seen alot of trex's with both types and they both have their pro's and cons.
Another thing i found during my test flights was that i needed quite alot of demand on my tailrotor to get it to a fast piro. That was with the Gy611 in both F3c and 3D modes, i'm used to having the tail whipping around at about half stick left and right. Would expo on my tail channel be the best way to speed it up or can this be done on the GY611 control amp?
I'll update this once i've made the modifications for anyone who's interested and try to explain what all i've changed on the heli and more importantly why!
I'm very much open to any suggestions and hopefully we can all benifit from eachothers experience.
