ds760 and jr8900g which servo horn?
  • ds760 and jr8900g which servo horn?
    which and what servo horn lenght do you use for your 600nsp/760/8900g setup? thanks...
    the trex 600 needs the rod length fairly short due to high mechanical gain. i would be looking at 13-15mm as a starting point and try both to see what you prefer.
      thanks.... what would be the effect of using the 13 vs 15 does it mean that i need to set the gain lower when im using the 15mm? thanks.
        yes that sums it up pretty much. the reason i say 13-15mm as a start is there are a lot of factors in getting this right. headspeed, tail blade choice, tt v's tail belt, engine tuning, vibes etc etc.
        in general if you find your gain value is too low then go in a hole or vice versa. all this applies to any gyro.
