The tricky bit is that the Shuttle uses an 8mm shaft. So most likely you'll only find multi-blade heads for a 10mm shaft and you'll need to round up a sleeve to adapt it, which shouldn't be difficult.
A Trex 500 head will fit but then I think you'd have a problem with the grips not being big enough for the blade root thickness.
and a platinum star
