Bit pitchy
  • Bit pitchy
    Got the 600e sorted in a way, it will hover hands off in one place but add a little more pitch and seems to go up quite quick and on the way down drops quite quick!
    atm its -2 +5 (mid) +10 to much pitch?
    Bit pitchy
    You can drop that to 8 degrees if its for a scale and you don't need the extra oomph!
    SAB
    Trex 500 FBL /
    Beast X
    Futaba 8FG
    Proud Owner of 2 EGS Awards
      you don't say if its a 2 or a multi blade head
      but i'd reduce the top end pitch and the throttle curve to reduce the head speed a little
      Hirobo Turbulence D3
      1/4 scale Vario Bell 47 G3
      1/3 scale Vario R22
      2012 LHC Scale Cup Judge
        Bit pitchy
        Good shout. I didn't consider more than 2 bladed head!
        SAB
        Trex 500 FBL /
        Beast X
        Futaba 8FG
          sorry standard two blade fb head ,md500 fuze. throttle curve is 0 75 75 75 75 ill drop it to 8
            Bit pitchy
            Have you considered dropping a pinion size or two and running closer to 100% throttle? You get better efficiency and your electronics aren't being worked so hard.
            I also re-read your post and you say it drops really quick too? Even with only -2? I'd double check you are only getting -2 as it shouldn't come down 'too' quick with that.
            Edit - have you tried setting your mid-stick to zero degrees instead of +5 and making mid-to-bottom stick the -2? I'm not sure how you fly your helis so I can only speculate. That way you have a very gentle negative curve. However, if you're used to flying +5 @ mid-stick then it might be too much of an adjustment. Do you do any sport/3D flying?
            SAB
            Trex 500 FBL /
            Beast X
            Futaba 8FG
              Usually fly 0 mid stick but was trying this set up. only fly sport flying no 3d ill try changing it when it stops blowing a gale and snowing!
              currantly have a 15 t pinion
