Finally happy with 600efl pro set up.
  • Finally happy with 600efl pro set up.
    Took a while to fine tuned and now im happy with the ice 80hv and vbar settings.All 4 of my vbars feel great now after reducing main rotor gains and the 3 with cc controllers have better settings of the motor and gov gains.
    Quick vid of the 600,spinning 2200 on the head
    Could you summarise how you tuned the governor for optimum performance? I've just started playing with mine and have left everything on default.
    Synergy E7 - 4525 Ultimate, Futaba 252/276, Vortex, YGE 160 ESC, HV2 BEC Alu, Rail 696/106
    Teams - Align-trex.co.uk / Synergy / Spartan
      nice flying mate, surely you have entered grass roots?
      Sab Goblin 500
        He is too good for Grassroots IMO
        Sweet flying Nick, youre definitely improving!
        Goblin 700
          sweeeet!
          Chris 'CHUNK' Newby
          ALIGN-TREX.CO.UK team pilot
          LYNX team pilot
          SPARTAN team pilot
          Dx18
            Basically I've flown it where the gov struggles so played with gain values to much where i should of tweaked motor settings.On my phone at the moment but will post up my settings later
            Thanks for your comments,waiting on a better keychain cam and had to use a crap one
              true
              Sab Goblin 500
                Nice flying Nick! Got quite a bit in your locker there!
                  Looking good Nick Looks like much better weather than sunday!!!!!
                    Vehicle Type:Helicopter
                    Throttle Type:set rpm
                    Governor Gain:18
                    Initial Spool-Up Rate:5
                    Head Speed Change Rate:18
                    Auto Rotate Enabled:True
                    Vehicle Setup - Battery Type:LiPo
                    Vehicle Setup - Number of Cells:12
                    Vehicle Setup - Battery Voltage:44.4000
                    Vehicle Setup - Gear Ratio:8.6154
                    Vehicle Setup - Pinion:13
                    Vehicle Setup - Spur:112
                    Vehicle Setup - Motor Kv:510
                    Vehicle Setup - Motor Number of Poles:10
                    Desired Head Speed 1:2008
                    Desired Head Speed 2:2100
                    Desired Head Speed 3:2200
                    MOTOR
                    Motor Start Power:Medium (59) (default)
                    Motor Timing:Normal (5)
                    PWM Rate:8Khz
                      Nice, I must get one
                      Rich (sirricardo).
                      Trex 250 Mini V-Bar, 300 motor, KST servos (smokin!)
                      CopterX 450Pro - 3GX (reset in flight x 2 - grrr)
                      Trex 500ESP - Spartan (on the shelf - too nice to crash)
                      Trex 550 DFC Head Mini V-Bar (Too mean!)
                        Governor Gain:18
                        MOTOR
                        PWM Rate:8Khz
                        Nice flying again Nick
                        Thanks for the info as Im just venturing into the world of Vbar..
                        Eddie
                        Velocity 90 FBL BeastX V3
                        Trex 600 LE FBL BeastX V3
                        Trex 500 EFL Pro BeastX V3
                        Fusion 50 FBL
                        VBar
                        All powered by a DX8
                          On the fusion??
                          if so,can post settings for that as its same motor and esc
                          Also the vbar settings if you wish
                            PS,you can higher the pwm to 12 or higher for even better performance but the esc does get really hot,you dont want to get a cc controller hot,believe me
                              Hi BladeStriker,
                              I would be interested to see your vbar settings for the 600efl, any chance you can post your setting file?
                              XL Specter 700, Vbar Neo
                              Synergy N606, 55HZ, Vbar Neo
                              Oxy 5, Vbar Neo
                              www.Hely-Shop.co.uk
                              Lynx Heli Innovations
