Electric users, MUST SEE
  • Electric users, MUST SEE
    I was quite shoched when i saw this, Such a simply problem!!!
    Well if you use the correct screws in the first place no problem,,
    This test would be relivent if you was to mega the motor with voltage to get a reading .
    Sent from my iPad using Tapatalk HD
    RAPTOR 60
    TREX 500 CF, FBL
    MSR-X
    JR XG7
    __________________________________________________ ______________________
    http://www.hdrcmc.co.uk/index.htm
      looks like my body has better conductivity than the motor )
        Thanks for posting that.
        I learnt something so thanks again
        Cheers Paul
        Citizen #42
          Another lesson learned. Cheers Chris.
            Thanks.... so simple to test.
              OMG my brand new Jive 80HV burnt at the very first time I plugged it, that may be an answer...Why do we need to learn it from Mr Mel and not from companies ?
              Mikado Logo 400/Kontronik Pyro 600-09/Kontronik Jive 80HV/Skookum SK540/3xS9650MG and MKS DS760/8s
              Goblin 630 incoming
                Because its common sense maybe.
                Sent from my iPhone using Internet.
                Gaui x7 lush
                Gobbalin 500
                ALL ON SPEKKY GEAR
                Blade 130x2
                nano
                  Common sense to check motor's IR once it's fitted on its plate ?
                  First time I read it after 2 years of hobby. I should have come to this forum sooner
                  Goblin 630 incoming
                    There's a long list of gotchas in this hobby. Perhaps a sticky would be useful for them.
                    Blade 130-X, MSR, MSRX
                    Phoenix Sim
                      To check bolts are the right size.
                      Gaui x7 lush
                      Gobbalin 500
                      ALL ON SPEKKY GEAR
                      Blade 130x2
                      nano
                        from my Gaui X7 post re- HK III 4035-500Kv 350S motor Quote:-(if you do go for this motor DO NOT use the 10mm bolts thay are to long! go for 8mm) the 10mm will short the motor! Nice one Chris Good explenation mate
                        Cuppa
                        GAUI X7 Beast X V3 (a nice bit of fish!)
                        Trex600n Fbl ys56sr BeastX V3
                        Trex500Fbl AR7200BX
                        Trex500 Apache x4bld BeastX. Trex 600E HIND mil x5bld BeastX
                        DX7se
                          i was quite surprised to see the inside of a RC motor and there was no phase insulation or case insulation, all that needs to happen is a little rubagainst the stator and its hard down!
                          Chris 'CHUNK' Newby
                          ALIGN-TREX.CO.UK team pilot
                          LYNX team pilot
                          SPARTAN team pilot
                          Dx18
                            I've always used the bolts provided in kits.
                            Goblin 630 incoming
                              Still worth checking incase of typo or wrong 1s supplied.
                              Gaui x7 lush
                              Gobbalin 500
                              ALL ON SPEKKY GEAR
                              Blade 130x2
                              nano
