T-Rex 600 Losses it Blades
  • T-Rex 600 Losses it Blades
    Ooops - well it could have been much worse if they had departed higher or at the wrong angle...
    type
    Added by: Stuart
    Tags: T-Rex 600 Losses it Blades
    Date: 2011-06-19
    More...
    ..headspeed was a bit outside any design specs?
    PGK
      i cant belive how fast the blade came out ,they could really hurt if they hit you .as you said lucky it was not higher or doing you fast backward flight
        i had the same thing with my 450, blades hit the side of my van, i was right next to it. s--- myself, em must put lock tight on both sides
        Ronnie
        Goblin 700 - HC3sx- Konny Pyro 700-52 - konny 120hv - bls 251 - bls 451s
        Goblin 570 -demon 3sx - konny 100lv - xnova motor - Bk 7001s -BK 7005
        Boggy combat plank - wot 4 - EFX - ECt ECt lol
        FUTABA T14SG
        PMHC - A128FREEFLY - Thurrock model flying club - TTI
        GUINNESS WORLD RECORD PILOT 2012 & 2013
        GRASS ROOTS 1st PLACE, FEB 2013 ( FOR BEST CRASH LOL )
          I think that is an understatement, the word death springs to mind
          TDR (in progress)
          SAB Goblin 700
          Vibe 90SG Vibe 500E
          Kalt Baron30
            I started to discuss this here but now I did a better calculation.
            I take the best m4 bolt - UTS 10699.4N (this takes into account the thread, uses the core diameter loaded in tension)
            Apply a safety factor of 2 (which is the last I would accept in a life and death situation).
            w(speed)=sqrt(F/mr) in rad/sec - a 600D (not the heaviest blade) is 0.125kg at a rad of 0.29m (flybarless blades are heavier!)
            =384 rad/sec or 3670 rpm.
            That is for a light 3D blade - not a heavier flybarless blade.
            Force increases with the square of the speed, but linearly with mass.
            If you get to 5000rpm with a 600D, then there is no safety margin and the blades are definitely coming off no matter how perfect the bolt and feathering spindle are!
            These calcs are purely the straight pull, and don't take into account the flexing on top of that due to manoevres!
            Some of these 12s electric setups sound a lot faster than my 2150 rpm on my nitro - so maybe they are approaching 3000 rpm?
            What may be much more important is you should only tighten that m4 screw to about 3 foot/lb, or 4 Nm or you may already weaken the bolt. Don't overtighten the bolt, you must rely on the loctite.
            On no account swap that bolt for a stainless steel one whuch will be weaker!
              Wow. That would literally got through a person. Ouch.
              RCHA Member
              LFXproductions.co.uk
                Ouch! Wonder if the blades were still usable?
                Harry
                Powered by Futaba 18SZ
                  crazy thats like a flyin samauri sword
                  RAPTOR 60
                  TREX 500 CF, FBL
                  MSR-X
                  JR XG7
                  __________________________________________________ ______________________
                  http://www.hdrcmc.co.uk/index.htm
                    how far do the blade travel when they come off, i only see a 450 and that surprise me how far they went
                      Had the same thing happen to me on my logo 500. same as on the vid, the spindle bold just snapped at the same place.
                      It was just an almight 'Bang' and the heli just dropped out the sky. Spent half an hour looking for the blades in the long grasses. Eventually found both of them. One was one side of the field, and the other was on the other, several hundred feet apart.
                      Only damage was the skids, and the canopy had a few scuffs on it. The blades, blade grips etc were all fine..
                      ANdy - CDMFC
                      Align 550 Beast X
                      Proud owner of 3 x E.G.S.
