Air ambulance take off rotor damage.
  • Air ambulance take off rotor damage.
    Even the pro's can have bad days. Didn't look like he had many options though.
    LiveLeak.com - Air Ambulance Takeoff Accident
    Could have been alot worse.
    Stuart
      Very Lucky! Makes you wonder why he never landed in that field in the first place.
      Proud Sponsor/Pitman/Servant/Slave to Bart101s fleet of Outrage and Avant helicopters
      Bart101 suffers from a medical condition called "Compulsive Inpulsive HeliAddict"
      sigpic X3
        I don't get why he just didn't go straight up. After all its a Helicopter.
        Mark
        www.uavaerialservices.co.uk
        BNUCs - Operations certified
        CAA - Permit for Aerial Work
          My thoughts exactly- seen a lot of RL RAF, CG and Air ambulance landings, but none as tight as that!!
          Synergy N5C with 3GX on the bench
          Trex 500 ESP FBL BeastX -soooooooooo fast
          Trex 700 LE Beast X'd and no sticky out bits
          Velocity 90 BeastX FBL-the love affair has begun!
          Newton Abbot Heli CLub where the sun always shines
            My first thoughts aswel.
              Looking at the video it seems there is a ditch between the field and the road, it may be that was a consideration for the injured person, could be they had a neck or back injury, so getting them across into the field may have been far more trouble or risky than landing in a tight spot, still a bad choice though.
              The best option would have been to look at another landing site further along the road somewhere that would have been more accessable (no ditch, or an access road) then drive them there in the back of the ambulance and transfer them to the helicopter.
              Current kit
              Evo 50
              T-rex 500FG night setup.
              T-rex 700N pro
              T-rex 450 pro
              10CP
              Frankenstarter (dynatron)
                That was my first thought too or at least come back a bit and take off sideways to the left into clear air. Damned lucky that cable didn't hit the tail rotor too, all the bystanders would have been in serious danger too if it had pirouetted and tipped over as they have a tendancy to do.
                I'll bet that pilot was beating himself (edit: herself ) up something cronic after that error!!
                VIC.
                JR DSX9
                TREX 600E
                Century GL450SE now an Align Airwolf
                Robbe schluter Jet ranger futura 111
                Planks.....Chris Foss Phase 6... Sebart Sebach 342 30E.......
                natures helicopters have the best HH gyros...... sigpic
                  woman pilot,thats what thay say at the start
                  500epro c/c bx dfc 7c 500 dominator g.pro
                    Oops!!
                    Koz
                    Total Relative noob
                      Very lucky it was the main rotor that hit the lines and not the tail.
                      Could have been so much worse.
                      Paul.
                      TD
                      R
                        I wondered why he did not back out of the confined space to give himself room for a bit of the old vertical
                        CCRAP
                        Clapham Common Radio Air Pilots
                        'May the Farce be with you'
                        You need no wings.........just 'set your mind to fly'
