[ame=http://www.youtube.com/watch?v=iEyUECEIZ0E]YouTube - Flasher 600E Sport with stock motor, esc, part 1[/ame]
New 100A ESC and phoenixtech motor
The UK's sole distributor of MKS Servos
www.mks-servo.co.uk
We are here to listen and support heli community
regards
andy jiangTags: None
fly the flasher 600e sport
[ame=http://www.youtube.com/watch?v=4jJ7RCixU6A]YouTube - Flasher 600E Sport with stock motor, esc, part 2[/ame]The UK's sole distributor of MKS Servos
www.mks-servo.co.uk
regards
andy jiang
At least the spool seems sensible which is a major achievement for a cheaper ESCPhil
Originally posted by moonmanflyer View PostSeems to have plenty of grunt, is that running a 12S set-up Andy?
we getting there slowly lolThe UK's sole distributor of MKS Servos
www.mks-servo.co.uk
regards
andy jiang
Originally posted by simm0 View Posthey andy
this is a real nice video,really usefull for the intermediate/sports flyer etc.
keep up the good work
craigThe UK's sole distributor of MKS Servos
www.mks-servo.co.uk
regards
andy jiang
Originally posted by Si_B View PostGoing with a 12s set up as an option is a great idea.The UK's sole distributor of MKS Servos
www.mks-servo.co.uk
regards
andy jiang
I'm having problems getting 0 throttle at low stick. It starts up when i turn off the throttle hold, but only just. If i put 4 clicks down and the DX6I trim it stops. How can i set up so that low stick is 0 throttle?
Thanks Lee
Originally posted by Lee 72 View PostI'm having problems getting 0 throttle at low stick. It starts up when i turn off the throttle hold, but only just. If i put 4 clicks down and the DX6I trim it stops. How can i set up so that low stick is 0 throttle?
Thanks LeeJames
Sponsored by
Align-Trex.co.uk
Optifuel/optipower
MKS servotech
Thanks for the quick reply. Is this just specific to that ESC? I have never had to do that to any other heli i have. They are all set to centre trim. Cheers Lee
Sorry can you run through the steps to do this please.
Hi Andy,
With Russ doing the dehind the seens testing and James(moonman) plus Steffan puting on the display to the puplic you will be very busy.I just said in a PM to Pete After the puplic see the TT360 V2 at a couple of flyins it will become very popular.
The Very Best,
Marty.Chase 360 and JR Ninja all controlled by JR XG8
proud owner of 2 EGS's
Ok i have got the 0 throttle sorted now. Took it to the field and did my first test flight. I have DX6I in Normal mode 0, 36, 75, 93, 100. got it hovering with about 75% throttle. Flicked to Stunt mode and...... nothing No change in power. I have stunt set to 100, 95, 90, 95, 100. Its not getting full power. I have reset the ESC to factory setting to make sure Governor mode is not on. Any ideas??
