DJI FC40 vid
  • DJI FC40 vid
    Looks pretty damn awesome for a basic rtf package.
    Vid looks like good quality and its got that GPS rtb stuff and all sorts.
    Might have to have a little dabble me thinks?
    good work nob nut
    James
    SEMAS Flying Club
      Get the Phantom 1 or 2 and put the zenmuse gimbal on it and fatshark fpv. It's what I have and a great combo. Yes it's more money but I guarantee you will get fed up of that one not having a gimbal on it.
      Phantom 2 is a bit more plug and play with zenmuse gimbal and iosd etc and has up to 25 minute flight time but the lipos are very expensive. About £130 I think.
      I have the phantom 1 with zenmuse, gopro 3 Black, IOSD and fatshark FPV. It really is superb. I also have the bigger props off the phantom 2 on it. i get about 8-9 minutes of fastish flying. If gentle hovering, probably 12 or so. The osd and gimbal etc require a small amount of soldering of connections and you have to cram the bits in, but it's a piece of cake once you get your head round it.
      Cheers, Rich
      SWRCH - Go Big or Go Home
        Build yourself a F450 and then when you think I want to throw it around more you can just strip out the base plates put in some TBS frames and hey presto new style quad minimum costs.
        The phantoms... you can keep them! You'll spend twice if you buy it
        Mark
        www.uavaerialservices.co.uk
        BNUCs - Operations certified
        CAA - Permit for Aerial Work
          No, tbh I don't want anything serious at all as I will use it for a little bit of filming at the field once in a blue moon so won't bother if its sits on the shelf for 11 months of the year
            Get a 450 or a 550 and build it,them cased jobbies are good till you need to go inside or you break the case!!!
