Hi again , my dx6 is full so I want to put my new 450 3d on my futaba ff9 with the specky module . Could you guys tell me how to set it up please ?
Eg what should be reversed etc
T Rex 600 n pro, Raptor 50 ( on the build table) T Rex 500 , Nano and a Blade 450 ,T Rex 250 ( still in box )
Aroura 9 , FF9 with specky mod , dx6i
Oh and loads of Planks.
I can't help from experience as I don't know anything about the FF9 but you could always just bind it and see how the servos move. You should be able to see which way the servos move and if they move in the wrong direction then reverse the appropriate channels.
The only one that is not so easy for is the throttle and that you can do by removing the blades and powering up.
Just a thought... :-)
MCPX E-Flight Blade 450X / AR7200BX
Planks - WOT 4 Foam E
