Need more with hc3sx setup on a dx8
  • Need more with hc3sx setup on a dx8
    Hi all
    I have trying now for days and getting nowhere fast. My heads about to explode.
    Got hc set up good on governor 3 way switch for 0, 36, -100. But I am trying to get it to be 0, 36 on gear switch and rescue of -100 on trainer button. I have inh governor and assigned aux2 for gear switch and all works great.
    The problem is the trainer button, in the monitor it switches from 0 and -100. So far so good...trying to apply mix from trainer button on aux3 and aux2. I don't understand mixing and can't find good tutorials that don't involve planks.
    Has anyone got a model save they can email me?
    Sorted at long last. Not really sure about mixing though so do you know were I can find tutorials?
    Raptor 50 v2, trex 600n fbl, trex 550 v2 3gx, trex 450 3gx v2, mini-titan v1, mcpx v1, WoT4 foamE, Gootch 450, mcpx bl.
    How did you fix this one? I am setting up the same and hitting the same problems AAAGH!
    MCPX
    Planks - WOT 4 Foam E
      Re: Need more with hc3sx setup on a dx8
      Yer tell me about it...major stress. Which bits you stuck on?
