I posted up a while ago about a tail rotor servo issue I thought I had, but was waiting to cure a noise I wasn't happy about.
Well, a MCP-X got in the way of that, flew, crashed, flew, crashed broke studs from skids into main frame, new mainframe time, flew, crashed, broke studs in mainframe, upgrade mainframe this time
Then Winter, then garage got messy, but bit the bullet and cleared the garage out, built a nice new workstation to use out of a bit of laminated chipboard so it's white and clean and little bits aren't going to fall off the sides, and dug out the 500 to start looking at the main shaft.
I looked for a video to see how it was removed, and found this one.
He's got a vibration which he can't solve, but the noise is pretty much the same as mine, are they normally this noisy? as if it's normal I don't have to worry about it being 1 second from self-destruct and can put it back together and give it a fly.
I've got to be determined, since I've got a TREX250 kit which I've promised myself is going to stay in the box until I get the 500 up and in the air
and a platinum star
