I need some help with finishing rebuilding my blade 300x, setting up etc
  • I need some help with finishing rebuilding my blade 300x, setting up etc
    Hi,
    I manged to stuff my 300x into my garage wall a couple weekends ago.
    I have completely rebuilt the heli other than the electrics, I am a little confused about what goes where onto the beast x, I should of taken more notice.
    Still new to the hobby I am still trying to work a few things out, I'm also building a 550 DFC so I think I better had the 300x flying perfect and use it to learn from.
    Iv got the swash back on and all the links and servos back how they were removed but I just want to be 100% where I plug in each servo etc.
    ALIGN TREX 250 DFC
    SPECTRUM DX8
    www.southhantshelis.co.uk
    It might be an idea to not connect the horns or the ball links until the servos have been plugged in to avoid stalling them. You can get the servo plug in info from the manual or you can work it out yourself. One servo will only work on elevator, that goes in the middle. The other two go either side. Swop them if they go the wrong way.
    Blade 130-X, MSR, MSRX
    Phoenix Sim
      If you can hold out til Saturday, Im happy to run through it with you in person.
      Logo 600 3D --- Vortex Vx1n
      JR Forza 700 --- Vortex Vx1e
      And the proud wearer of one
        oh, and did I leave my SD card in your DX8?..
          Cheers Jimmy, I'm not 100% if I am free Saturday Due know I have not checked, I am at my other halfs house tonight but will check for you.
          I must say I haven't noticed. Will look for you...
          How's your 600, have you flown her yet?
          ALIGN TREX 250 DFC
          SPECTRUM DX8
            Thanks.
            That's actually helped me get my head round it. I will disconnect the ball links then connect the battery up and get the elevator sorted first, once iv done that I'm 50% there Is the elevator marked on the beast ex? Sorry I havnt got it to hand.
            ALIGN TREX 250 DFC
            SPECTRUM DX8
              600 is still sat on the bench, waiting for me to finish setting her up, have almost finished the fuel system, just waiting on some glue for the header tank. Might be ready for the weekend, but very limited on places to fly now.
                Brill, yeah agree I didn't think it would be so hard to find places to fly, Shame really isn't it
                ALIGN TREX 250 DFC
                SPECTRUM DX8
                  Doesn't have to be marked. You know it's the elevator if the servo moves when you move the right stick up and down. It seems obvious now, but it took me a long time to realize how obvious it is.
                  Phoenix Sim
                    Ok so Iv plugged it all in, ready to go, spun up the motor slowly and noticed something isn't right, the tail is all over the place it seems if I go up on the throttle they try to adjust the tail the motor either speeds up or slows down, doesn't make sense! I thought maybe the belt was to tight so when I adjusted the tail the extra load on the motor slowed it down.
                    This isn't the case, completely confused now
                    ALIGN TREX 250 DFC
                    SPECTRUM DX8
                      Sounds like you've got your wires plugged in wrong, ie sounds like you've got rudder plugged into your throttle channel?
                        Yeah seems like that, on the beast x I guess RUDD is the tail and THRO is the motor?
                        ALIGN TREX 250 DFC
                        SPECTRUM DX8
                          Yep. Rudd goes to the tail servo and thro goes to the ESC.
                            Arh, that's the only two I have plugged in and it's still faulting, can the connectors go in upside down? I don't think they work upside down but don't want to try it
                            ALIGN TREX 250 DFC
                            SPECTRUM DX8
                              I think the slots are keyed. Besides which, you should be able to see against the other connectors that the same colour cables are all going into the BX the same way. I assume when you say that's the only two you have plugged in, you mean, the only two you have changed - not that none of the cyclics are plugged in yet!?
                              Have you relocated the BX maybe? From inside the frame to at the back - a la 450X?
