neon blaze trouble
  • neon blaze trouble
    hey there newbie here, the prob ive got is that when i push forwards on the right tx stick, the blades tilt to the front and right, so its trying to drag itself sidewards, is there a way of setting it so so goes staight rather than angled? i managed to set the tail rotor out to stop it from spinning so now it sort of hovers (a bit). i'm new to heli's and dont know the technical terms so please be gentle lol. any help much appeciated.
    the simple way of setting any heli is set both sticks to the center. look and see if the swash plate is level. if not adjust the links till it is.
    dont forget to disconnect the motor first or you may have a problem checking
    obviously its a bit more complicated than that with pitch etc but its a good start!
      What is the helicopter, transmitter etc,
      TDR (in progress)
      SAB Goblin 700
      Vibe 90SG Vibe 500E
      Kalt Baron30
        im assuming if he's a beginner it'll be these
        http://www.centuryuk.com/Products/He.../Neon+Blaze+CP
          cheers for that. swash plate doesn't quite look level. and i shall have a read of that last link, cheers chaps.
