So i finally thought id fixed the problem with my heli spinning in circles by glueing the pully wheel to the rear rotor shaft.
now i can stop the heli spinning until it lifts off that is
Heres what ive noticed : when everything is switched on apart from the motor when i push the left stick left and right the rear rotor blades move accordingly but as soon as i push forward on the stcik the blades move completely to one side if i reverse the gyro then they move completly to the other side. Am i correct in think that the gyro thinks im accelerating the blades and compensates for the torque of the main blades by sending a signal to the rears to move further? ive tried moving the gain up and down and doesnt make any difference.
also when i push forward the sevo for the blade pith clicks and gets faster as a move further forward on the stick and sometimes keeps clicking (almost sounds like a motor spinning) even when ive stopped the blades i guess its getting stuck somehow. should this servo make the same noise as all the other servo on the heli?
