I've had about 10 flights on my new T-Rex 450 Pro now. When I assembled it I put grease on the bearings as best I could, but I know I didn't do a good job. I ordered a greaser from the US and it should arrive any day now.
Assuming the bearings had minimal grease when shipped and my attempt to add grease wasn't effective, how many flights would I expect to get before the bearings wear out?
Also, has anybody had a bearing wear out? What is the effect? What do you look for to tell if a bearing is worn or not?
Lastly, if a bearing is properly packed with grease, how many flights would you expect it to last for before needing replacing?
I understand there are a lot of variables and what-ifs in the above, but I'm really looking for general advice and pointers.
Thanks.
Thanks.
