gov. setup
  • gov. setup
    I have moved from a dx7 to dx8 and would like some help with the gov settings this is for my trex 600 using the align gov.on the dx7 i only used the gov either on or off and set it using the travel adj.now i am looking at the screen on the dx8 and it has three settings all at 0% and thats as far as i have got :-( as not sure what % to set. any suggestions would be appreciated .and keep them clean :-) cheers
    Trex 550e dfc :-)
    t-rex 450s x2 /Raptor 50
    kyosho spree small plank
    bogey combat plank x2 woop
    http://www.cuffleymfc.co.uk
    means you can have 3 gov speeds in that menu or you can inhibit and use as you did before on dx7.
    you can change at bottom right of screen mark sw,
    so if using gov will be on 3 position switch
    or fmod will be on your flight condition switch eg norm 60, stunt 1 80 stunt 2 85
    Santander Factory Team
    Proud wearer of 5 x EGS
      ah.the fmode .does that mean i have to set the throttle curves to .normal strait,1 say 80 and 2 say 90
      Trex 550e dfc :-)
        no, just set the throttle curves as a backup incase gov fails then will revert to curves in radio.
        norm linear curve
        idle 1 v curve
        idle 2 v curve
          thats the way its set up atm but then do i set the gov to use the fmode.
          Trex 550e dfc :-)
            if you wont or change fmod to gov then will be on 3 position switch
