Been there, done it, read the book but how.....
  • Been there, done it, read the book but how.....
    do I solve a ESC problem ?
    Firstly - Hi Guys - The Heli bug has finally hit me....
    I have only been into RC since this time last year when my wife bought me a £25 car from the gadget shop.....thereafter I moved to a Tamyia TNX - then another for parts, then another because it was on ebay and I'd had a wine with my tea....then a Losi Mini LST, then a Losi LST.... then a Tamya Subaru - oh then a letter from the bank manager to tell me I was overdrawn......joke ! But near enough true.....
    I then joined several forums and the local RC Truck Club where I took part in a number of races....
    Anyway- all the while I kept getting pangs to fly and again, with a glass of plonk in hand bought a Blade CX2 just before Christmas.
    I have flown it quite sucesfully since then but just today I hit a tree and consequently the ground from about 30ft.
    Here is the problem............
    The upper blades spin but the lowwer don't.
    I have swapped the motors from one jack to another and find both motors/blades spin from the upper jack point but not the lowwer (left).
    Do I need a new ESC or is there a wayof resetting or fixing the fault.
    Given many many crashes in my trucks at 30mph head on into trees, I find it hard to accept the ESC has given up with just a simple and light fall to the ground !
    Help...... this is the unit in question EFLH1024
    Thanks in advance...........
    Graeme
    Just because I can type does not mean I can spelle !
    Buy it, use it, sell it - buy something else...
    Tamyia TNX - Losi MLST - LST - Micto T - Tamyia Subaru Impretza - Spectrum DX3 - Blade CX2 - Wrangler 1978 YJ Jeep - Zodiac Medline II -P50 The Warren, Abersoch.
    hmmm thats a new one . note the position of the adjuster in the proportional pot . then try turning it full one direction and try then full other direction and try. this will give more power to each motor in turn and give you an idea of whether or not the esc is goosed! do it with the battery conected then disconect and reconect to test
      Yep......
      Yep....tried that - but nothing - still the same issue ;-(
        i find it hard to believe myself but it does look like it may have cooked it.
        all the plug pins are intact i presume!
          has it got the seperate spektrum rx?
          quick edit i see its a 4in one so no it wont have
            are the shafts bent to the point the lower blades wont spin? do they move freely by hand? id strip it down and check it to be sure
              Errrrr....
              Errrrrr..... No - at least if I understand the question correctly....
              It is RTF ffrom the box with no additions as yet.......
                his post says they both work from the top plug!
                  The blades....
                  .... the blades seem to spin without trouble - as mentioned, when connecting the upper and lowwer blades/motors to the upper 3pin jack, both upper and lower spin without trouble...
                    Yep.....
                    Yep.... all pins are intact - it just seems impossible to have cooked the ESC.......and they are bl**dy £69 to replace here in the U.K. ($59.00 Stateside)....Rip-off-Britain.
                    Any other thoughts ?
                      doh! should have read it better! it sounds like you may have damaged the mixer unit. fix it and take it back to where you bought it and deny all knowledge of the crash?
                        graeme you say you bought it just before christmas? i would do as jamie says take it back to your lhs. if you bought it online contact e flite here
                        productsupport@horizonhobby.com that isnt a link its an email adress
                          You devils.......
                          ........I would never dream to do such a thing to my LHS ......
                          Unfortunately, I bought it off ebay so I'm stuck with it and will just suffer the cost of replacement - however, I have already emailed Horizon with the advice that the ESC has blown and with surprise regarding the same - lets see how they revert....
                          In the meantime, thanks Guys for your prompt responses......I will now go and enjoy the rest of the site and catchp with you at a leter date..
                          Are there any club sections here (meets) ?
                            sorry we couldn't help any more but here is a list of clubs try and find your closest
                            http://www.bmfa.org/links/Model_Clubs_UK/
                              I had a twister bell47 and crashed it several times, its final demise was when the motor shorted and popped one channel in the ESC. dont forget, if you crashed with power on and the blades could not turn then this would load the system more
                              My guess is you have cooked the box!
                              TDR (in progress)
                              SAB Goblin 700
                              Vibe 90SG Vibe 500E
                              Kalt Baron30
